Thanks Eddy, it was with out my present, but point is if it is legit?
.. light sold with out shade and no one word of recommendations in a manual.I would think the inspector is basing it on a non-existent manufacturer's requirement that the light not be used without a shade.
"good order"?"put in good order" is subjective as possible.
...then, what rule is applied? and how could pass missing shade in shadeles fixtures?
so, in your opinion, shadeless pendant lights will not pass inspection as inspector will treat them as defective?The code has already been posted.
If the inspector failed the install then the fixture will not pass the way it is. He considers it defective.
Are you an electrician?
