- Lockport, IL
- Retired Electrical Engineer
Good point, Jon. Too often we believe whatever our instruments are telling us, without understanding how they make their measurements, and what their readings actually mean.
Plausibility question:
I know that a residential KWH meter is supposed to measure _power_ consumption. The theory of the meters that the torque applied to the spinning disk is supposed to be proportional to the instantaneous product of voltage and current. However I have never tested this.
Is it possible that an improved power factor will result in a reduction in the meter reading even if the 'true' power consumption remains the same?
-Jon
That is misleading too, the impact these have on the POCO's efficiency is so minor, would take many years to make up the energy used to produce the actual device, not to mention the energy that is consumed by the magic box of capacitors.
Electromechanical meters measure kW, not kVA. In older times, utilities used another electromechanical meter that measured kVAr (by shifting the current by 90 degrees).
I know that electromechanical meters are _supposed_ to measure real power, not apparent power, and are supposed to integrate to get kWh.
My question is how much error is introduced by 'quadrature' current and non-unity power factor.
-Jon
You are joking right?
100407-0745 EST
WinZip:
There is no possible way for the device you mentioned to produce the the electrical energy savings you describe.
With any reasonable knowledge of electrical theory about circuits you would never propagate such grossly inaccurate information and try to sell what is a fraud.
There is no reason to use a KWH meter to do the test. A far quicker and more useful test is with a wattmeter. You connect the wattmeter, then connect and disconnect the so called power saving device and see how much the power changes. Note: essentially a KWH meter performs an integration of the output of a wattmeter. Integration means summation. In an ordinary rotary type watthour meter the counter (dials from a gear train) is the integrator. The rate of rotation of the disk is the wattmeter.
Do you work for some power saver device company?
No I do not work for any power saver companies,was just telling you what I did for a friend who bought it off the Internet an he is convinced his savings are because of that PS unit,and as far as what I meant about testing I think you might see something different in readings with a 2 week test or a 1 day test.
Again I seem to have posted something I should not have.
WinZip
Please tell us more.The company I work for sell real energy optimizers which provide measurable kWh reduction . . .
WinZip
If the motor's moment-to-moment speed (by motor, I mean the meter) is dependent upon instantaneous voltage and current, it seems that improving the power factor would increase the speed of the meter for a given voltage and current. Hmmm.The theory of the meters that the torque applied to the spinning disk is supposed to be proportional to the instantaneous product of voltage and current.
ZOG,
I never said I sold them all I said is I Installed one for a friend an he claims it has saved on his electric bill over the last 14 months an he uses his equipment the same as he did before this was Installed.
I will tell him you think he is nuts - point is he still uses all that equipment same as he did before an his bills have reduced quite a bit over the 14 months,other than that I don't know.
Now, you want to buy my gas saver thing? Only $29.95![]()
I hope that you are not talking about the PowerOptomizer which claims to use "specific wavelengths of infrared light to stabilize the vibration state of "spinning" electrons.... The company I work for sell real energy optimizers which provide measurable kWh reduction but we spend so much explaining the results. I wish I could just show some tricks... I have just finished few hours of analysis, got an impressive 15% saving in kWh, sent to the customer, and started to get requests for further explanations... I think the difference is between selling to layman vs. engineers.
Yes as long as you include a Slap Chop
Maybe Vince could make PF correction devices sound fun and cool.![]()
