weressl
Esteemed Member
winnie said:Yet this 'outlandish' concept is an explicit part of the NEC, if only for _outside_ circuits. Similarly, feeders with a common neutral are explicitly described.
Clearly, at some point in the past, someone thought that these were a good enough idea that the NEC placed strictures on how to use these methods.
My gut tells me 'Unexpected and confusing design with no significant benefits.' Do you have a firmer reason for not using such circuits?
-Jon
OK, let me see if you can answer this question:
Let's use A1 and A2 for the two different circuit breakers.
Breaker A1 has a load of 12A.
Breaker A2 has a 17A load.
What would be the current in the common grounded conductor(neutral)?
