Wire-Smith
- United States
using two legs not two phases.Because some of us have been taught that 120/208 or 120/240 is two phases of a three phase system, not a center tapped single phase system as used in 120 volt transformers in the UK. There is some differences in how the power is calculated and used. Actually, I am slightly wrong in this. If you have a 110/220 or 120/240 type system where you measure line to line as double the voltage of line to neutral, then you more than likely have a center tapped single phase system. However, if you measure and have line to line 208 or 230 and line to neutral 110 or 120, then you more than likely are on a three phase system using two phases. The variance is within the normal operations of most consumer equipment and most people would not ever know the difference in use. But, the harmonics on the neutral are different, and the calculations are different. Not installation calculations but conversion of power calculations.
However, not too sure any of this would help the OP. But, I was taught to call center tapped as two phase as you have a positive and negative phase at same time, compared to three phase. Currently it is simply single phase then three phase as teachings go. But other countries still teach single phase - two phase - three phase.
single phase is one sine wave, its what you get with two legs whether two ungrounded or one grounded one ungrounded. three phase you have three sine waves, you need three legs. two phase, two sign waves, usually four legs
