I knew an old farmer that just put a big pulley on the motor and started it by hand.I guess the pony motor idea can work as well.
I looked into this about 6 months ago and I found it to be About the same cost.If a planer has a 3HP or smaller motor a single phase input VFD could be more economical then a motor swap.
I would opt for the VFD.I looked into this about 6 months ago and I found it to be About the same cost.
I figured that. Might not even need to do much more than accelerate to 1/4 to 1/2 running speedPony just gets it to rpm, then disconnected.
You do need to make sure you are only directly powering the three phase motor and no controls or accessory items via the VFD.If a planer has a 3HP or smaller motor a single phase input VFD could be more economical then a motor swap.
