I was doing some reading on three phase and single phase today. It talked about how u could use a phase convertor to get 3phase out of single phase. Can anyone explain how this works and is this the only way to do it?
[*]Rotary Phase Converter (RPC), which uses a 1 phase motor to spin a 3 phase motor, then uses the 3 phase motor to "add-in" that 3rd phase
A static converter (well at least the store-bought type) is nothing more than a motor starter, and once the motor is up to speed, the converter drops out completely and the motor is left to single-phase. I have heard of only one company that offers an option for balancing capacitors for their static converter. It is commonly stated that a static converter will provide 2/3 the motor power, but I am pretty sure this is incorrect, but it has been repeated so much (even by me in the past) that it is considered true by default. In retrospect, I think it is more like 50%.
- Static Phase Converter (SPC), which is done with some basic electronics and capacitors. Sometimes called an "Add-a-Phase" unit.
This is called a pony motor converter, and in my opinion is a waste of two good motors, and it is only marginally more effective than the motor starter of a static converter. Unlike a generator, there is no field winding (or permanent magnets) in the idler motor. If you put a meter on the generated leg while a load was present, you wouldn't find much of any power generation, but enough to get your tool motor started. If you put balancing capacitors on, it would bring the power up to a more usable level.
- Rotary Phase Converter (RPC), which uses a 1 phase motor to spin a 3 phase motor, then uses the 3 phase motor to "add-in" that 3rd phase
