DanZ
Hey everybody. I got in a discussion the other day with someone about 2 phase alternating current. He told me (in great length, at great detail) how he defined 2 phase alternating current as taking two phases from three phase a/c transformers. I want to try to correct him about 2 phase, but I want to make sure my understanding of it is correct before I attempt to explain it. I have also googled it, but it's not used quite enough to be a major find. So, here's how I understand it.
-Single phase, generally a residential a/c electrical service (that can be found in commercial applications) whose sine wave is a single line between -170V RMS and 170V RMS.
-2 Phase, not broadly used, created (discovered?) by Tesla and used to make more efficient motors. Sine wave is two lines 90 degrees offset from one another. Can be derived from three phase with the use of a Scott T transformer or Scott Connection.
-Three Phase, generally a commercial or industrial a/c electric service with two major transformer types (Delta and Wye). Sine wave is three lines that are 120 degrees offset from one another. When properly used, this allows there to be no zero moment in voltage, considered the most efficient service for motors.
-Split Phase, Connection that uses the system ground and one other live conductor to mimic a single phase system. I'm unsure of how the sine wave looks. Technically referred to (according to wikipedia) a 3 wire, single phase, mid point neutral system. Erroneously referred to as 2 phase.
Do I have it down, or am I missing something?
Please remember:
I have read the battle of the phases, I just want to make sure I have it down.
This is not the battle of the phases, please don't turn it into it.
Leave the horse alone.
Please remember:
