SG-1
- Ware Shoals, South Carolina
Actually, he probably said the phasor rotation is CCW. If he used the term "phase rotation" I'm sure he did so in the context of "sequence".
As rattus has stated, phase sequence is the proper term. The term "phase rotation" is used but it is not what we might call "proper english".
Rattus properly covered phasor rotation in his post #10
He actually said:
"Phase rotation or, preferably , phase sequence is the order in which successive phase phasors reach their positive maximum values. Phasor rotation is, by international convention , counterclockwise in direction. Practically, then, phase rotation or sequence is the order in which the phasors pass a fixed point.
All standard relay diagrams are for phase rotation a, b, c. It is not uncommon for power systems to have one or more voltage levels with a, c, b rotation; then specific diagrams must be made accordingly. The connection can be changed from one rotation to the other by completely interchanging b and c for the equipment and connections." END QUOTE.
No matter if the sequence is abc or acb the phasor diagram shows the rotation anti-clockwise. The arrow heads for phasors b & c are exchanged, to designate the difference.
