H Hadrian Parsons New member Jul 31, 2006 #1 I am intrested in finding out if the NEC code has an article about colors such as y,b,o or b,o,y or b,r,blu. Thanks, Hadrian Parsons
roger Moderator Staff member Location Fl Occupation Retired Electrician Jul 31, 2006 #2 No and yes, do you have a code book? Roger
iwire Moderator Staff member Location Massachusetts Jul 31, 2006 #3 No the NEC does not specify which phase and voltage is which color other than grounded (white / gray) grounding (green / bare).
Minuteman Senior Member Location The Sooner Nation Aug 1, 2006 #4 Tell us a little bit about what you need this info for. To settle a bet? Test question? Curiosity? Bidding a job? Inquiring minds want to know.
A andrew Member Location Florida Aug 1, 2006 #5 This is out of the 2002 NEC.... BLUE....322.120C...400.22C...424.356....504.80C BROWN...4524.35...517.160A5(2) ORANGE...215.8...230.56....408.3E...424.35...517.160A5 RED...322.120C....424.35...517.160B1 YELLOW...424.35...517.160A5 LIGHT BLUE 400.22C...504.80C Andrew
roger Moderator Staff member Location Fl Occupation Retired Electrician Aug 1, 2006 #7 Andrew, 517.160(B)(1) is refering to an LIM warning lamp, not a phase or conductor color, and 110.15 needs to be added to your orange list Roger
iwire Moderator Staff member Location Massachusetts Aug 1, 2006 #8 Andrew it might help if you put some descriptions of each section as most of them are fairly obscure and do not apply to general wiring.
A andrew Member Location Florida Aug 1, 2006 #9 Roger and Bob, I dug that list up from all the other semi useless lists I have. I just threw it out their for general info. A describtion will be worked on and 110.15 should have been on the list. Thank you both Andrew
