hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
This is not a cable TV company providing internet and land line service to me. This is AT&T telcom.
Same thing today.
-Hal
In some areas, AT&T is a cable-TV (+internet+telephone) company, depends on why they bought and when.This is not a cable TV company providing internet and land line service to me. This is AT&T telcom.
Initially, I had only heard the TV ads, but your concern led me to get the actual plan description at https://www.xfinity.com/learn/internet-service/stormready. The new service is specifically branded as "Storm Ready". It provides broadband connectivity, including a WiFi access point. And presumably if the cable modem is supporting a voice line that will be backed up too.You have to be careful here. The battery backup often kept only phone service working to provide access to emergency services. That was only POTS. Backup for Ethernet and TV was not provided.
This is where your confusion over the term VOIP comes in. As I stated above, most people do not have VOIP phones.
This is why I strongly recommend your own UPS if you want to use your computers and other internet connected devices during an outage. Cable companies give you nothing that they don't have to.
-Hal
The Frontier systems in this area were formerly GTE. I guess I don't know how GTE compared to others back in the day but it was better maintained here when GTE was still operating than after Frontier took over. I seem to recall Citizens Communications was the name between GTE and Frontier. They didn't do that bad of a job in comparison to Frontier at maintaining the system either.In some areas, AT&T is a cable-TV (+internet+telephone) company, depends on why they bought and when.
Remember that the AT&T of the last 15-20 years has almost nothing to do with the Ma Bell/AT&T of per-divesatature days - see the chart at https://en.wikipedia.org/wiki/AT&T_Corporation.
And Frontier? They bought the LEC parts of GTE, which historically were terrible. There have been a lot of name changes to try getting away from a bad reputation.
Then you’re also depending on the cell tower being maintained. One of the big cell providers we did work didn’t have a single tower with working batteries when we did the upgrades. Most were in the large suburbs or big cities though, so power outages were not that common.Initially, I had only heard the TV ads, but your concern led me to get the actual plan description at https://www.xfinity.com/learn/internet-service/stormready. The new service is specifically branded as "Storm Ready". It provides broadband connectivity, including a WiFi access point. And presumably if the cable modem is supporting a voice line that will be backed up too.
But it does not rely on the upstream cable infrastructure being intact. Instead it abandons the cable entirely and connects instead to a 4G cell network, if one is available. And it is indeed limited to 4 hours of backup on a fully charged battery.
Cell towers out here in the boonies all have stand by generators from what I can see. Never worked at any those sites but they all have generators at the site. IDK if they also have UPS to ride through until generator comes on line or not. But out in the boonies they are more subject to several hours of outage at times. And when we had ice storms about 20 years ago some would have been down for possibly up to 10 days, presuming they were there back then.Then you’re also depending on the cell tower being maintained. One of the big cell providers we did work didn’t have a single tower with working batteries when we did the upgrades. Most were in the large suburbs or big cities though, so power outages were not that common.
Was that the phone line you share with your neighbors and you get a special ring when someone calls your 'number'?Originally I had a two party phone.
Getting off topic here, but the problem with streaming is that the interface sucks and it doesn't matter what TV or box you have. Left, right, up, down, enter, navigation on a remote makes me pull my hair out- especially in the dark.Most the local cable TV operators have or are in process of switching over to only providing internet service and you need to use streaming services to watch your TV programming. I get why they are doing this, but it is hard for some non tech savvy people particularly some elderly to learn how to use it.
In the simplest form a party line could support two parties with "normal" ring timing by applying the ring voltage either from tip (red) to ground or from ring (green) to ground. by using different ring voltage frequencies and tuned bell circuits this could be extended to four or six parties without requiring the use of distinctive ringing cadences.Was that the phone line you share with your neighbors and you get a special ring when someone calls your 'number'?
We had that when I was very young. I don't really know details as I was maybe 6 or 7 years old when we moved from that place. I do remember the being able to listen in on other conversations thing. Also remember my mother talking to friends and apparently you only could talk for so long before the system gave you some warning and eventually disconnected the call so that it would free up the line again for others? May even been an operator that told them to end the call? I remember mom always saying "I'll call you back" then hung up and pretty much immediately called back and continued their gossip session.In the simplest form a party line could support two parties with "normal" ring timing by applying the ring voltage either from tip (red) to ground or from ring (green) to ground. by using different ring voltage frequencies and tuned bell circuits this could be extended to four or six parties without requiring the use of distinctive ringing cadences.
The talk circuit was indeed common to all parties, allowing eavesdropping and causing problems billing for toll calls when direct dialing was available.
Yeah I don't think it's as simple as "POTS only needs power at the office end". I think a phone line is only good for about 4 MI before you need some sort of booster or repeater, that I assumes need power.....Putting the equipment at your end will really not help much. From you to the telcon office are MANY "boxes that require power. They are supposed to have batteries, but they don't last very long. Our area lost power during the night. My end was fine, but the "box" down the road shut down. Dear old windows was doing a update when the "box" went down and trashed my operating system big time!! I was on AT&T.
A real POTS line can go for miles, limited only by the supply voltage (nominally -48v) and the resistance while still getting 30-ish ma current. Ma Bell even had special switch modules that would use -96v to get a longer loop.I think a phone line is only good for about 4 MI before you need some sort of booster or repeater,
You could well be more versed in POTS than me, but almost every source you see from a quick Google search says about 4 MI. There are certainly "tricks" to extend that, and I assume some require power out in the field along the way, and some can be deployed at the CO?A real POTS line can go for miles, limited only by the supply voltage (nominally -48v) and the resistance while still getting 30-ish ma current. Ma Bell even had special switch modules that would use -96v to get a longer loop.
What you may be thinking of is that the lines had series inductors ("loading coils") spread along the line to counteract the distributed capacitance. (ISDN lines needed the coils removed and were only good to maybe 18k ft without a repeater.)
