rexowner
- San Jose, CA
- Electrician
You'd have to define 'properly-made connection' first. But, if we're talking about screw terminals, how many times have you guys opened up a switch or outlet in an old house and been amazed at the dark brown (sometimes green!) that the copper wire has turned to under the screw, that's obviously not gas-tight. It still works for AC (more or less), but with a constant DC voltage on the circuit as in a phone line, it causes static. This is why the so-called 'tip' conductor is actually earth grounded at the central office, to minimize electrolysis of underground cables.
Jerry,
Sorry, but you are incorrect.
The gas-tight connection in IDC's occurs at the metal, not at the insulation. Here is one easily accesible source with
other links:
http://en.wikipedia.org/wiki/Insulation_displacement_connector
Do you have a source wrt your argument that the
insulation makes a gas-tight connection?
Insulation's purpose is to insulate, not to seal against
gas penetration. If your argument about not stripping insulation were correct,
then connections of any type would not be made with
wirenuts, screw-lugs or other connections including
IDCs which make a gas-tight seal at the connection.
