archibald tuttle
I'm trying to locate a source for the small cheap dusk to dawn photocells supplied with various outdoor fixtures to be able to retrofit them onto exterior fixtures of preferable aesthetic that are not available with the preinstalled capability.
The standalones I can get from local electrical wholesalers and/or big box competition are going on as expensive as some of the entire light fixtures I have purchased with onboard dusk to dawn photocells ($15-20). And, to make matters worse, they are more bulky and difficult to install in a fixture escutcheon, being mostly intended to hang off a 1/2" threaded knockout on an exterior box or cover.
These fixture mounted units are made to fit in the maybe a 1/2" diameter hole similar to that you would use to mount a push button or pull switch onto an unswitched fixture.
Has anybody found these available through local commercial infrastructure or on the internet.
Thanks,
Brian
Thanks,
Brian
