Photocell
mstrlucky74
NJ
Anyone come across fixture mountable photocells. I have a small office with about 15 fixtures on the perimeter and the fixture cut calls for a fixture mounted photocell. Why would you need one on every fixture? Thanks
Several of these can be mounted inside or on the surface of a fixture: https://www.homedepot.com/s/photocell?NCNI-5
If they aren't powered from the same switch leg that goes from fixture to fixture, you can switch with photocell from each fixture, but you will have slight variances and they won't all come on at exactly the same time.
If the circuit goes from fixture to fixture, you can wire the first photocell in series with the hot wire and then it is the only one you need.
That depends on how much wattage you're switching through the photocell and if the photcell is rated for that much.
Right so if you had 4 fixturesright next to each other on the same switch leg you wouldn't need a photocell for each, correct ? Thx
