Andy1845c
- Southern Minnesota
Hello all,
Been lurking for a while and finally decided to jump in with a question.
I have two of these transformers to install. I haven't installed many before and decided it would be interesting to pick apart the nameplate.
The application is stepping down 480 to 240 for a piece of industrial equipment. Nothing weird. Mostly just hypothetical questions here.
http://imgur.com/uoRbEf8
Question 1. Can someone explain the drawing at the bottom of the nameplate - it appears the only difference is in one X2 and X3 are connected together and the other X4 and X2 / X3 and X1 are connected.
Question 2. I don't need 120v for what I am using it for, but I assume it could be used for 120v if I wanted to? Center tap being X2/X3?
Question 3. What are the various taps for? I assume there number are for input voltage? What are some situations where I would use something like 432v or 216? What is the 240 volt tap set up for? This one is confusing me.
