innersurffer
If, for instance there is a 4" x 4" box that has a ground screw and a single device (i.e. receptacle) and there is 3 wires coming in (ground-green,neutral-white,and a hot-any color) should the device be attached to the ground by an old school method I learned along time ago of wrapping the green wire (ground) around the ground screw and leaving enough extra green wire to go directly to the ground screw of the device, or should it be pigtailed separately with a wire nut making 3 ground wires (0ne wire would be the ground coming in, one would be the ground from the ground screw, and one would be from the ground of the device)??? I prefer the second method just because of the ideal of the initial ground, if broken, would not potentially ground the box in the first situation. Can you give a code relating to the second method or have I been overdoing it for the last 7 years? Also, what if this situation was in a daisy chained series of receptacles?
