120 V SINGLE PHASE ,Rec circ not working, Pin plug shows hot and Neu revered. Tested and found 120 to Grn on Neu and on Hot, but same phase ,no 240 accross Neu and Hot. Checked panel, switched breakers, opened all devices looking for problems but all test the same.Then circiut misteriesly returns to normal. Got call back 1mth later after big storm, Bath has lights on switch loop and same thing Neu to grn 120 ,Hot to grn 120. Circiut started working again while removing and testing all devices misterisly.I turned on lamps,tested every outlet ( note: all resisitive loads) with pin plug all tested o,k,.I leave and customer plugged in fax and boom back to problem again. Could this be a aplliance problem and if so How come system does not return to normal upon removing appiance IE: fax machine ?.
