Hydraulic.
How does the process work?
Hydraulic.
One mechanism is that very turbulent water produces an actual negative pressure region in which a small bubble forms and then collapses, causing a hydraulic shock wave that produces very high surface velocities and forces.How does the process work?
I can't see this happening at water pressure levels in a house. Google "aggressive water" if you want to learn about a more likely explanation.There is the possibility that small hydraulic eddy currents are created as the water flows through the pipe. These eddys could create wear in the walls of the pipes.
And get a comfortable chair and few months worth of snacks.Use clear couplings so that you can monitor the water.
What he said.One mechanism is that very turbulent water produces an actual negative pressure region in which a small bubble forms and then collapses, causing a hydraulic shock wave that produces very high surface velocities and forces.
A similar mechanism causes cavitation in poorly designed propellors or ones which are used at too high a speed. Again the symptom (besides inefficiency) is corrosion to the metal surface.
RO?May not be related to the OP's problem, but if you run RO water through copper pipes, the RO water corrodes copper piping.
What is your source for that information?
RO is just a filtering process at the molecular level. It's about the purest water you can get. How can anyone say that's detrimental to copper piping?
Google it. This is from Cornell University: "The storage tank, tubing, and dispensing faucet should be made of plastic, stainless steel, or other nontoxic materials. The low pH and mineral content of RO-treated water may corrode copper pipes and allow lead to leach into the drinking water from brass components."
http://waterquality.cce.cornell.edu/publications/CCEWQ-04-ReverseOsmosisWtrTrt.pdf
That's incredible. I always thought RO water was neutral pH. (7 I think?).
I don't think pH is much of an issue, it it the fact that pure water (or nearly pure anyway) has more room for dissolving things then water that already has dissolved content in it.That's incredible. I always thought RO water was neutral pH. (7 I think?).
Never been there, is he the Mike Holt of the plumbing trade?I feel like I am at Terry Love's plumbing forum reading this thread.
Not a bad thing, just unexpected.
