macmikeman said:Drilling holes in concrete decks is no big deal when using a Hilti rotary hammer drill, it goes almost as fast as using a hilti gun and threaded studs.
My prefered method over the years for threaded rod hanging has been using drop anchors, but you have to double check and take care in installing same so you don't get pull out failures. (I'm not really positive if they are listed for upside down use, but work great there anyway). 2nd choice would be using parabolt anchors. Third is the 3/8" hilti studs fired from the hilti gun. (concrete blowouts common). Now Eric, if a small little bitty blip of an establishment way out on a sandbar in the middle of the ocean can afford a 3/8" Hilti gun, surely a multinational jet set megacorporation with headquarters in New Jersey for crying out loud can, can they not??? :roll: :grin:
i don't know....jet fuel is through the roof
