Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I have a job installing a 50 amp RV power outlet for a car charger. The plan is to run the 8-2 UF through the attic and down the side of the house to the RV outlet. The UF cable will be sleeved in a 1" PVC conduit directly into the top of the box.
https://www.homedepot.com/p/Midwest...orary-RV-Power-Outlet-U054PP-U054PP/331418048
The power box has pre drilled holes for a 1.5" conduit hub. How do I transition from 1" PVC to the power outlet that is set up for a 1.5" conduit?
