electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
Would you do anything with the steel in these pictures as far as grounding and bonding goes and what NEC rule would cause you to do it?
Steel beam spanning two car garage set on two steel columns. Will be fully concealed within the building finish.
Two ceiling beams for added structure sitting on wood walls and wood lvl.
Deck framing. Columns seen in foreground of picture are mirrored close to the house. (can't be seen in photo) All steel will be boxed in with colums, ceilings and decking, none will be exposed.
