kwired
Electron manager
- NE Nebraska
- EC
Thank You Gold; Can you define what the permanent moisture level is? I am sure that it is different from El Paso vs Seattle.
I am pretty certain whatever it is it changed a couple years ago here during a dry spell, but has since pretty much recovered.
I think keeping the rod away from the foundation wall (where there is a basement) also probably helps some with it's sphere of influence, but NEC doesn't mention this either.
As far as keeping out from under a roof overhang, doesn't the wind ever drive the rain in TN to some angle other then true vertical? It sure does here.
