Shockedby277v
- Michigan
When are plastic screw on bushings required to be used???
300.4(F) Insulated Fittings. Where raceways containing ungrounded conductors 4 AWG or larger enter a cabinet, box enclosure, or raceway, the conductors shall be protected by a substantial fitting providing a smoothly rounded insulating surface, unless the conductors are separated from the fitting or raceway by substantial insulating material that is securely fastened in place.
Exception: Where threaded hubs or bosses that are an integral part of a cabinet, box enclosure, or raceway provide a smoothly rounded or flared entry for conductors.
Conduit bushings constructed wholly of insulating material shall not be used to secure a fitting or raceway. The insulating fitting or insulating material shall have a temperature rating not less than the insulation temperature rating of the installed conductors.
infinity said:or the conduit is rigid threaded conduit.
infinity said:Bushings are required when the wire within the conduit is #4 or larger or the conduit is rigid threaded conduit.
iwire said:or rigid non-metalic conduit.
infinity said:Does RNC require a busing on a terminal adapter for conductors smaller than #4?
infinity said:I say no, Bob says yes. IMO the edge of the terminal adapter is just as smooth as the edge of an EMT connector. IMO neither require a bushing for conductors smaller than #4.
ARTICLE 352 Rigid Nonmetallic Conduit: Type RNC
352.46 Bushings.
Where a conduit enters a box, fitting, or other enclosure, a bushing or adapter shall be provided to protect the wire from abrasion unless the box, fitting, or enclosure design provides equivalent protection.
FPN:See 300.4(F) for the protection of conductors 4 AWG and larger at bushings.
benaround said:I find it strange that the code says "--a bushing or adapter shall be used--"
but a male terminal adapter does not qualify as an adapter?
What other fitting would be called an adapter, I can't think of any!!
I guess " It says what it says " is not always true.
