Plastic sheet covers for labelling the panel
KdogSparky
Wisconsin
Lately I've been printing out my own breaker directory for my breaker panels, mostly resi work. Looks professional. I've been just taping them to the inside of the door. Ive thought about using plastic sheet covers so I can pull the sheet out and add to when needed. Wondering any ideas about to just affix the sheet protector to the inside of the panel door and then slide my print out right in. standard printer paper.
Reasoning is obvious, they never give me enough room for some extra detail, plus my handwriting is bad, and my Brother brand labeller just takes too long, esp. if something gets moved around in the panel.
Thoughts?
I worked at a place that used clear packing list envelopes, and I liked the system they had. It was easy to read, it stayed in place, and any edits/changes could be easily managed.
I shrink mine down when I print them so they don't hang off the sides of the door. I also have an Excel workbook that I got from here many years ago. It not only does the directory, but it also does the load calculations if you enter all the information.
-Hal
Guys, come on get with the program here. Industry standard is handwritten with pen. There will be some mistakes so also some cross outs. Writing should be barely legible. leave several circuits unidentified with a question mark. Printed out panel legend in a protective sleeve, LOL 😂
You forgot that some descriptions need to be misspelled, like dinning room, refridgerter, garge, harthe room....
I think Industry standard is to not label anything.
If they do any label anything just write "lights" or "receptacles"
I have too 😅
An old Ryan's steakhouse, I rewired the whole seating area lighting. Then the Chinese owner wanted me to re-label everything and it was all written in Chinese 🫣
It's funny because I had written an PI to require that the directory be written in English which follows the actual native language of the NEC. I never submitted it.
I print out the directory using Excel on a full 8.5 x 11 sheet of paper and use a plastic sheet cover installed on the door with double faced tape.View attachment 2581101
That is a good system! Lots of room for details. I use clear protectors from Siemens and an excel spread sheet that is about 5”x5”. And I always print two panel schedules, charged get marked up, one goes to office for correcting and reprinting
Many commercial panelboards have had a removable directory card with clear plastic protector for decades. Most still were not large enough for what some may want to put on them.
I generally use a Brother label maker, one that I connected to my PC and can adjust sizes of fonts or even print images if desired never done that for circuit directories but have for other labeling at times. Can print one label per breaker or can print one long vertical label and space the individual entries along that length according to breaker alignment. Save the file and if there are future changes you change the file, reprint and apply new label if you want. That is handy for places you do regular work for maybe not so much for most residential work, unless maybe you are doing new cookie cutter houses.
I find even looking for the breaker/circuit # embossed into the panel is difficult to see. We all know the breakers are usually # #1 top left #2 top right etc but the HO doesn't know this and they count down vertically sometimes. I buy sticky sheets of Avery label paper and print out two strips to # the breakers so you can see what # it is, 2 pole breakers are numbered 'Circuit #2 &#4 or #6 & #8 for instance.
Then I make up a panel directory with the circuit #s and fill in the information and stick it on the panel door.
I have a Microsoft Visio program so I can change the lettering size, sheet size so it will fit on the panel door. No room for corrections, however. I print out a couple of copies. 1 stuck to the panel and one loose copy to hang on the wall.
