readydave8
re member
- Clarkesville, Georgia
- electrician
I've heard that its better to use a metal box with dimmers as they dissapate heat better than plastic--is this true?
You dont have to bond the box as you would with metal. plastic is non conductive cant be electrified. Does not corrode. Ive seen moister get to metal boxes and they decay over time.
kbsparky;1107381} :grin: They can't short out on a bare piece of wire said:That's a good selling point for the customer.
I would think that using a metal cover plate would be more effective.I've heard that its better to use a metal box with dimmers as they dissapate heat better than plastic--is this true?
I'd say the fact that billions of them have been installed and in use is good enough for me.
You wouldn't have to buy any with metal boxes either.![]()
the builder wants me to use the same metal boxes that we use when piping these homes.
Can some of you people give me some reasons as to why plastic is as good or better than metal when installing romex?
I forgot to add.
Some have an issue with the threaded hole for the device screw. What some do is use metallic raised roughing covers on 1900 boxes to alleviate this issue.
I used to shun plastic boxes as a contractor, but today, the market is so tough and the quality of plastic boxes is better, that I would use plastic myself. It keeps the weight in the truck down too.![]()
No problem; go right ahead.I want to restate this, if you all do not mind.
Thanks. I enjoyed that. :grin:I used to shun plastic boxes in the past. Today the market is so tough and the quality of plastic boxes is better than in the past (for me the past is 20 years ago). I would use plastic boxes is certain installations today, and carrying them in the truck does keep the weight down too.
John - what town in N. Illinois are you working in? I am also in N. Illinois.
Thanks
like this one?
He wants metal boxes because after that romex burns up, the boxes will be all set to
use EMT !!
Pairs of vertical 2x2's or 2x3's flanking the vertical NM's rising out of each panel.Those cables running horizontal above the panels, what are they fastened to?
use EMT !!
