ericsherman37
- Oregon Coast
What is the difference between plenum rated and riser rated cable? What about just regular ol' stuff?
Riser can me used in walls.. etc. Only plenum can be used in a place such as a drop celieng, that is used as way to transport air.
~Matt
I believe I heard somewhere that the plenum rated stuff has some sort of property where it won't produce as much, or less toxic, smoke if there's a fire. Is that correct?
From what I understand from tool5150, you can use plenum cable for riser cable applications PLUS air spaces?
Fire spread along the cable is a factor, too.
