conmgt
- 2 Phase Philly
I am wiring a few woodworking machines. They have a variety of motor sizes and have power cords for ease of mobility. Each machine will have a dedicated breaker and single receptacle. I remember something in the code about a single receptacle's rating needing to match its breaker. For example...a 15A single receptacle is not permitted on a 20A circuit but a 15A duplex or a 20A single is. If I'm sizing my branch circuit conductors to 125% of the FLC and the breakers to 250%, what is the minimum size receptacle permitted? For example, one saw has a 10hp motor. The conductor will be rated for 30A and the breaker will be 60A. Does the receptacle need to be rated for 60A or 30A? I think 30A since the conductors are rated that. Any thoughts?
Also, on that saw there is a note from the manufacturer that says a 30A circuit is recommended but consult your electrician. It has a 10hp motor and a nameplate rating of 24A. Should I go with 24A x 250% = 60A or the 30A?
