publicgood
- WI, USA
300.22(C) is pretty clear. Plug-in busway under raised access floor are not permitted in a plenum application. My question comes with the wording of 368.10(B)(2). It makes it seem opposite of what 300.22(C) is saying. Also, are there concerns for working clearance of the plug-in units?
(B) Behind Access Panels. Busways shall be permitted to be installed behind access panels, provided the busways are totally enclosed, of nonventilating-type construction, and installed so that the joints between sections and at fittings are accessible for maintenance purposes. Where installed behind access panels, means of access shall be provided, and either of the following conditions shall be met:
(1) The space behind the access panels shall not be used for air-handling purposes.
(2) Where the space behind the access panels is used for environmental air, other than ducts and plenums, there shall be no provisions for plug-in connections, and the conductors shall be insulated.
