Captainjon0107
- Littleton, Colorado, USA
I am trying to troubleshoot some older homes for remodels, and I keep running into poor or nonexistent ground connections at receptacles. Even after verifying that a ground wire is indeed connected, I can't get the plug tester to show and I'm not getting 120v between the hot and ground on my meter.
Short of going box to box and checking every connection in the circuit or crawling in an attic or crawlspace to hunt down a bad ground connection, what other options do I have to solve this?
My two immediate thoughts are:
1.) Put in a GFCI instead of a standard duplex recep. Won't the GFCI trip if there's an overload, regardless if a ground connection is present?
2.) Put in a non-grounding duplex recep.
Will either of these options be legal with regards to the code?
I know I can pigtail off the neutral and get the same function, but I don't want to do that, since it's not code.
