J
jonny1982
Guest
Is it necessary to install plywood behind an electrical panel if it is on an outside wall? If so, where in codebook?
Are you talking inside a basement?
In the old days when foundations were built in field stone you would put up plywood, today you can use plywood and studs or unistrut, but it's not required in the code. But mounting a panel direct on a concrete wall and you will get condensation in the panel and that is not too good.
