Have a ground rod with GEC attached which passess through the meter can that has a disconnect in it and ends up in the panel at the neutral bus. It is not attached to the meter housing at all....except he has it bonded to the bushing at the pipe that enters the meter housing from the panel. There water service is also grounded to the panel. Is this acceptable?
