sparky723
- Haskell,Tx
I got called out to the prison were I work Last night during a hard rain. On the phone they stated that 5 pole lights were out. I arrived and sure enough all 5 were out. BTW, on top of each pole light, there is a 1000w and 2 400 w fixtures. (30' poles). Anyway, I checked the panel and the breaker for these 5 poles was tripped. I reset it and 3 of the 5 came on (lets say A,B, and C). Then after a short time, they went off. I rest the breaker again and this time in the contactor box (nearby the panel) I heard a POP! I went back to look at the 5 lights and the lights A, B, C were back on. While I was in the elec. room, some people were watching the lights and said "the middle light (1000w) on pole C arc'd" Later stating there was a bright blue flash...With it pouring down rain I decided to clock out and go home. On the way out I talked to the mobile patrol who just happened to be watching the lights at the base. He said "It (pole C) arc'd at the bottom". I told him "OK, I'll check it out in the morning."
Today, I went to the base of pole C (middle of the 5 poles) and also where the feed comes in for these 5 poles. I noticed the wires (2 hots,1G) going to poles D and E were burned in two. I made neccesary repairs and checked for voltage at the pole C. I got 283 on each to ground. I went and check for power (with tick) at base of poles A and B. I showed power at each pole. As it was getting close to the end of the day, I energized all 5 poles , but no light on any of the poles lit up. (I gave them an easy 15-20 mins.) The lights are metal halide I believe. There was hardly any lighting during the rain, if any.
SIDENOTE: the externally ran conduit from pole C to poles D and E had been previous hit by tractor or something, leading to the shorting of the wires and me having to re-wire this section of the wiring to poles D and E.
Does anyone think the problem might be up top somewhere within the lights?
I feel I have troubleshot most problems on the ground.
Please help, sparky 723:-?
