I have a 240 volt 1 phase site lighting circuits that feeds 240volt to pole. This cicuit is a 240 volt 2 pole GFCI breaker.
If I install two fuses at the pole can I tap off this 240 volt source and adding a neutral from the same panel as the feed install a 120 volt GFCI outlet on this pole by tapping off one of the two fuses at the pole that feeds the 240 volt fixtures??
