kwired
Electron manager
- NE Nebraska
- EC
Inverter driven pool pump? Do you get this voltage if pump is turned off?Thank you. I can give that a try.
With the pool situation - last question.
If I am getting 0 volts ac but 0.4 volts dc in the pool water, should I consider it safe?
Is it possible that the dc voltage reading is just because of the chemicals in the water are essentially making a large “battery” when the circuit is complete with one probe in the water and the other to ground?
Any lighting in the pool? Pool heater, electric operated pool cover? any of which utilize DC voltage in any way?
