Seems to me that is talking about a separate surface/structure than the pool structure. Note it mentions when the perimeter surfaces is separated from the pool by a wall. But then they throw this in at the end "For nonconductive pool shells, bonding at four points shall not be required.". As is typical and prevalent in the NEC, The wording is just garbage .
It's talking about either re-enforced steel (rebar), copper grid, or the alternate means (#8 encircling the pool) attaching to the perimeter surface of the pool at 4 equally spaced points. That's the outside of the shell/structure, perimeter meaning all the way around.
Bonding to
perimeter surfaces shall be provided as specified in
680.26(B)(2)(a) or (2)(b) and shall be attached to the pool
reinforcing steel or copper conductor grid at a minimum of
four (4) points uniformly spaced around the perimeter of the
pool.
(a) Structural Reinforcing Steel. Structural reinforcing steel
shall be bonded in accordance with 680.26(B)(1)(a).
(b) Alternate Means. Where structural reinforcing steel is
not available or is encapsulated in a nonconductive compound,
a copper conductor(s) shall be utilized where the following
requirements are met:
(1) At least one minimum 8 AWG bare solid copper conductor
shall be provided.
(2) The conductors shall follow the contour of the perimeter
surface.
(3) Only listed splices shall be permitted.
(4) The required conductor shall be 450 mm to 600 mm
(18 in. to 24 in.) from the inside walls of the pool.
(5) The required conductor shall be secured within or under
the perimeter surface 100 mm to 150 mm (4 in. to 6 in.)
below the subgrade.
