jjhoward
- Northern NJ
- Owner TJ Electric
I am wiring a filter pump (120V) and heater (heat pump 240V)for an above the ground pool. Not sure if it is > 42 in deep (I will measure it). Pretty sure that the walls are nonmetalic, thus a Storable pool? But there is one wall section that is definitly metal (polished stainless)where the filter lines go through.
What should be done re: bonding the pool? There are steel struts, covered with molded vinyl/plastic holding the walls up. Should that shiny metal wall section be bonded?
The filter motor has a twist lock cord. The heater will be hard wired.
Suggestions, tips? Thank you.
shiny metal construction is
