Desert Sparky
- Desert
- Electrical Engineer
I'm working on the design for a small backyard addition, which will include a pool with a single pool light fixture. I'd like to extend power from an existing GFCI-type receptacle to feed this pool light, but want to confirm I'm meeting the GFCI requirements in 680. In addition, the pool light will also be switched.
Can the existing GFCI-outlet provide code required GFCI-protection for the pool light per 680.23(3) & 680.23(F)? Or would I need to provide an additional blank face GFCI in between the light switch and the light fixture, down stream of the existing receptacle? My concern is adding the second blank face GFCI could cause nuisance tripping at the existing GFCI receptacle.
Thoughts?
Thoughts?
