Sorry, Another Rehash BUT
Clearly, it would appear that it was the intent of article 680.25 in requiring a four wire installation to ensure that an insulated grounding conductor be provided, continuous, from the pool light to the service panel since it quite obviously conflicts with past theory that suggested that a three wire installation to a non service panel was indeed a safer installation.
First, I am not sure about the word "continuous." Although I have always defined this as "unbroken," or "without splice" I am uncertain that the code actually provides a definition. Since "continuous" as supplied from the light manufacturer is a relative impossibility (and I have tried replacing it) I would therefore be inclined to reinterpret or revise my definition of continuous in this case.
Secondly, I was hoping someone more technically aware might expound on the actual theory behind such a requirement as this continuous grounding conductor from light to service panel. Why are we doing this? Why not simply terminate it in the non service panel?
Third, I am uncertain that is appropriate to suggest that there is significant difference as regards safety of installation between that of a building, and that of a structure. I therefore view this particular wording, with interpretive focus on the one word "building" as something likely, purely incidental to the cause in a) continuance, so as not to appear in conflict, with their initial 3 wire requirement and b) advancing their cause for a continuous pool ground to the service supply.
However, it is also quite possible that there is significant theory behind the four wire requirement to a pool structure that I simply do not understand, or have never been educated in. Can someone please expound on this a little as well?
By the way, my intent is not to manipulate the code or challenge those more enlightened. It is simply to more fully understand. So, uhh, thank you very much for your time and consideration (and please don't beat me up too much).
