pool pump gfi breaker
[QUOeve david;1574419]If it is 120 Volt pump supplI check and seensee if the equipment ground is in contaneutralizing the neutral terminal.[/QUOTE]
The egc is not contacting the neutral in any way, i have no continuity between hot terminal and case nor neutra to case. I am going to megger tonight to see what I can find.
