paul renshaw
- Cordova, Maryland
On a storable pool, is the following installation code compliant? Pvc and wiring from the house buried at 12", circuit is protected by a GFCI breaker at the house. Conduit is 1", with 12-2 UF inside. Outlet located at least 10' from the pool. Outlet is standard receptacle, not twistlock. Pool pump is plugged into this outlet with weatherproof in use cover. A co-worker of mine did this at his house and the inspector shot him down for not having a twistlock and said depth must be 18". The pool is above ground with max 42" of water. I have not dealt with many of these above ground pools, any info is appreciated. Thanks, Paul
