I need to wire a 500 gallon above ground diesel tank for equipment at an excavation business, they bought this used, it has a 3' piece of 1/2" sealtight hanging off of the pump, a wp bell box with blank cover and 12" # 14 romex hanging out the end. It is 120 volts, I couldnt find anything in the code book, but I am thinking a 15 amp circuit with a disconnecting means at the tank (SP switch) Diesel is non combustible (fumes) so nothing needs to be explosion proof?? am I correct? anyone hooked one of these up?
