Re: Portable Generator GEC & EGC
Hello Ronald, I got your message sent to the webmaster, thanks a lot.
You have submitted a good article. The ground current flow in a MGN system will also affect the GFP zero sequencing of the generator, when the neutral is not disconnected. The sensor sees this as a fault and will dump the unit off line.
This, of course is on units with GFP protection.
The transfer switch, as shown, will not disconnect the MGN (neutral).
