But it CAN be a bad idea in some instances. Current can use a ground rod to flow in either direction! We design our systems so lightning induced current flows from the structure to the ground in an organized (well bounded) fashion. This is best achieved by bonding everything together and directing it to ground via the GEC. When multiple ground rods are in play, especially when separated by distance, one must carefully evaluate how the entire system is bonded together. If lightning strikes the ground near the structure, a voltage gradient is created. If two rods exist across this gradient, and both are connected via the EGCs in the structure, then current can flow between the two rods running through the EGCs. Instead of shunting current to ground, the extra rod becomes an enabler in energizing enclosures in the structure. Bad idea.
