That's not how rules stack.
If earlier in (2017) 310.15 were a statement of the form "when applying ampacity correction and adjustment, the base ampacity shall be the lesser of the insulation temperature rating and the termination temperature rating" then we would need the permission granted by (2017) 310.15(B) second paragraph. But we don't have any such statement, so we don't need the permission granted.
Word games. The lack of such a prior statement does not change what 310.15(B) says.
A statement of the form "A shall be permitted if B" doesn't imply "A shall not be permitted if not B." So if not B, we just ignore the second paragraph.
Yes it does. It is its' logical contrapositive.
Now, if you wanted to make the argument that, like a computer program, since the condition was not satisfied, we cannot take the action that it was giving us permission to perform, and THEN we "ignore the paragraph," and "the program continues to run..." I suppose you could argue that.
But you can't just throw away the reality that 310.15(B) explicitly requires permission to perform this function based on a condition which must be satisfied (at least the way it is current worded does).
So the question then becomes, can we just defer back to 110.14(C) which gives us permission to utilize a higher temperature conductor for correction and adjustment? I'm of the understanding that when there are conflicting rules, the most restrictive is king.
If you wanted to argue that since we failed to satisfy that condition, so we cannot perform the function, and now must look for our answer elsewhere, such as 110.14(C)(1)(a)(2), which gives us permission to utilize a higher temperature conductor, but requires us to set the ampacity at the 60*C mark, I would accept that logic.
But the follow-up problem to that is, we have not performed the required corrections and adjustments, but merely satisfied 110.14(C)(1)(a)(2)
Basically the second paragraph paragraph of 310.15(B) is... badly worded...
Agreed
