shawn73
- Napoleon, Ohio
I have been an industrial electrician for almost 5 years and I am also working on an electrical degree. There is an engineer at my plant that I always ask questions and 99.9% of the time his information is valid. We had a discussion the other day in which I don't agree with him, or perhaps I truely don't understand. Here is my question...
I was told that fuses are for short circuit protection (phase to phase) NOT short to ground protection (phase to ground. Is it true that a fuse in some situations will not blow even though it has a solid ground? I can understand if you have a very slight ground that there may not be enough current to exceed the protective rating of the fuse. My head tells me if there is a difference of potential between 2 wires (ground always being 0) and they are connected without a load, current will increase until it excedes the rating of the protective fuse. Am I correct or did I miss out on some sort of theory??? Does transformer winding configuration (Delta or Wye) make some sort of difference? Thanks for all your help.
