chursf
New member
- Houston, Texas, USA
I am installing a simplified power monitor system based on the EATON IQ-35MA.
The circuit being monitored will be a Line-Line (2 Wire, no GND) 240Vac 60Hz Single Phase system.
To prove out the monitoring device I will use an assortment Meters Fluke Multimeters for Voltage, Clamp On for Current, and a Multimeter to verify freq is constant at 60Hz.
With that noted: What are the base formulas I should be using to verify my field readings?
in example: Power = Volts X Amps X power factor
Thanks
Scott
Thanks
Scott
