sparks1
- Massachusetts
I've noticed that on most single phase pole mounted transformers, that are used for 120/240 volts secondary, have one primary H1 line feeding into the top of the transformer.
Can someone explain, why is this?
How is the primary H2 connection made?
It appears from a distance looking up, that the H2 connection come off the side of the transformer and is grounded to the secondary drop and ground rod at the pole.
What is the device that is wired in series with the primary fuse called. I looks like a lighting arrestor?
