Re: Power company transformer
you can model a transformer as an AC source in certain problems, but its operation is quite different from that of an alternator.
True.
Although the primary and secondary currents are separate and never "mix", the primary current is actually regulated by the secondary load.
a. With the primary energized, and no load (or fault) on the secondary, the secondary current is zero, and the only current that flows in the primary winding is an excitation current. This is quite small, generally only a few percent of rated current, because the core flux, and thus the primary impedance, is high and is mainly inductive reactance.
b. At constant frequency, the only variable in the impedance of either winding is the inductance which is proportional to core flux.
c. When a load is connected, and current flows in the secondary, it creates a flux that is in opposition to, and therefore reduces, the core flux created by the exciting current. This reduces the primary impedance, allowing the increase in primary current required to supply the load.
d. Any increase in load current in the secondary, creates an increase in the opposing flux, further reducing the core flux, and thus the primary impedance, allowing the increase in primary current required to supply the additional load.
e. Under no fault conditions, for any increase in primary current to occur (in addition to the exciting current), there must be an increase in the load current flow in the secondary. In other words, primary current is proportional to, and
is controlled by, the secondary current.
Ed
