Hi Guys,
I am called in to investigate power disruption problems in an industrial facility. Apparently, strange power failures occur without any notice. Certain portions of the building will suddenly go out without any breakers tripping. Voltage is not detected when tested. After some time things come back on again with proper voltage. They have 480/240V.
The electrician believes the 3 (75kVa) single-phase transformers servicing the facility are faulty and wants to replace them with one 225 KVa 3-phase transformer.
Are the transformers the problem? And is this replacement a better alternative to the existing setup for this type of facility?
