Hello,
could someone assist me with the following calculation.
I have a 8-pole synchronous machine (as a generator), which is rated to produce 1000 kVA. Its synchronous reactance is 0.4 Ohms.
It is connected to a diesel engine with the grid frequency 60 Hz.
I need to calculate the speed, power factor and power angle.
I know the following:
- Speed can be calculated by: n = 120 * f / P , where f is frequency (60 Hz) and P are poles (8) ... and we get the result 900 rpm.
- Power factor can be calculated by: PF = sin(PA), where PF is power factor, PA is power factor angle (is that the same as power angle?)
So, how can I calculate power factor and power angle?
