Power Factor effects of an inverter on the Grid
If it's programmable, the most likely place to look isn't the inverter documentation, it's more likely to be the control equipment documentation, and likely then it's buried.
The last inverters I worked on could do leading or lagging power factor to some crazy-insane number, but it had to be requested through the management hardware, it wasn't something that could just be "set" on the inverter through an easy to read data sheet.
